Regular Lexicon has it, it’s still beta and will be for a while probably because it’s not perfect yet so tread carefully (backups!)
with the new External Apps feature and USB support One library, I dont need to use Lexicon or Mixo, it was good apps though.
Lexicon is the best music library management program on the market.
Convenient track preview, metadata editing, playlist creation, automation of track analysis processes, and distribution of tracks to the necessary folders…
Djay Pro does not have such convenient options and most likely never will.
If Lexicon adds the ability to transfer playlists to a USB drive in OneLibrary format, it will be a tremendous enhancement to the program’s functionality.
I use a free old Java app to manage my library to Serato, still works perfectly, my main reason for Lexicon and Mixo was to convert my Serato library to Djay Pro, but I dont have any reason to do that now, Lexicon and Mixo are also still buggy and wasnt doing a great Job with Serato to DJay pro conversion, which still states that its still a beta,
Hi @Christiaan can you help me out?
How can i access the Comment field Djay Pro is using in Lexicon?
COMM (Comment): “This is the comment djay pro is displaying”
TXXX (User-defined text): Description = “LEXICON COMMENT”, Value = “” (or the reverse)
Is this true?:
COMM Frame Support: Yes, Lexicon can write to COMM, but only via field mappings in the Write Tags tool. By default, it doesn’t auto-write to COMM to avoid overwriting “standard” comments from tools like iTunes. From the official manual: “You can select any field you want to write or skip… [including] Comment.” This mirrors the file’s ID3 tags to Lexicon’s database, including COMM.
thanks!
I have used Lexicon before and loved it. Actually I did something similar with your genre portion of the app with equipment/sub-class management with the asset management work that I do (for a living). If you ever are looking for a lexicon/DJAY Pro (windows) user to test some beta stuff let me know.
