Can anyone confirm if the SB2 now works well with Djay Pro? I’m thinking of replacing/upgrading my son’s basic controller with the SB2, but want to make sure it works well with Djay Pro.
Thanks for the quick reply, much appreciated. May the purchase begin !! We will only know how it works in a few weeks time, when my son is allowed to unpack his new controller …
Hey guys just signed up to comment this thread - maybe some of you will read it (hopefully)
I am owner of DDJ SB2 and as Traktor is on sale right now I wanna buy Traktor. Traktor Support told me its possible to use Traktor with DDJ SB2 but I have to do own mapping.
Above I read “Its now official supported” is there an a mapping file to download? Could you share a link with me ? THANKS
oh sorry thanks for your advice!
But all in all does this work? never thought about djay pro before but i thinks its cool to use it with spotify
does it work with ddi sb2?
and do you know if djay pro works with cdj2000?
thank you so much man!
how do you link it to vertual dj? the mappers
how do you link it to vertual dj the mappers? i have ddj sb2
If I buy Djay pro for my IPad will I be able to use it with the Pioneer DDJ SB2 or will it only work with the Mac version of Djay pro?
Will It connect using djay via my iPad
i need the serato or virtual dj mapped for pioneer dj serato ddj sb2 please
i need the serato or virtual dj mapped for pioneer dj serato ddj sb2 please help me
Hi Miles, does your mapping working totally?;). Can you put the download here again? many thankss
Are you telling me that traktor its just plug and play now? Thats is not need mapping? I ordered the ddj-sb2 not yet arrived.
Hello, can you tell me how to setup that?
can i use my usb cord that comes with it and play it off my laptop I’m trying but its not working
Can you play sound out of your laptop with just the usb cords for the DDJ-SB2?
What about to virtual dj8
Hi guys! How to connect Pioneer DDJ-SB2 to djay 2 for android? Where i can read the info/manual? Will usb powered Hub help? thanks!
you can export the mapping from your PC or Mac to your iPad.
find the SB2 mapping file on your PC. open iTunes and connect your iPad.
on iTunes go to APPS. scroll down to DJay Pro. click add file. find the mapping file and then sync the iPad.
skeet. skeet. now your iPad will work with the SB2.
this will work with most other controllers too.
