New Reloop Mixtour Pro Hardware
Hi @PoyTB,
  1. Are you asking for a Mixtour Pro Manual or a MIDI Mapping Manual?
    a. The only manuals for the Mixtour are the ones from the Reloop website. Please note that in addition to the Instruction Manual, there’s also a Laidback Luke Signature Features Manual Reloop Mixtour Pro - Reloop
    b. For MIDI Mapping we have the following FAQ specifically for iOS: https://help.algoriddim.com/hc/en-us/articles/360016055199-How-do-I-MIDI-map-a-controller-on-djay-for-iOS
Please have a look at these and first, then let me know if you have any further questions?
Thank you! I’ll get back to you over the weekend! :slight_smile:
You’re welcome @PoyTB
Almost 1 year my main DJ setup.
3 open format gig’s every week, the mixtour is a reliable combo with iPad Pro M4.
Powered with Baseus 100W charger.
Nice! Thanks for sharing @Erwin_Deschoenmaeker. I have the same setup.
Looks like Luke has switched away from using the Mixture Pro, back to Pioneer CDJ’s. I wonder if his licensing deal has ended and now we’ll see prices drop to something reasonable ($250?). Currently it’s $50 (USD) lower than it’s ever been (edit: still $500)
I don’t want to be down on the guy, so I won’t. But from what I’ve seen of him over the years, he seems to chop and change, maybe to freshen things up with his DJ’ing.
I do agree the Mixtour Pro is a tad expensive, but it’s a genuinely quality bit of kit and if the workflow suits, I’m sure it’ll last for years. I bought one, but I bought mine 2nd hand and for what I paid for it, I’m happy, although I’ve been looking for a Mixon 8 pro 2nd hand too.:grin:
Thanks for the input @BillPayer
I’ve got a little side project going where I’m building MIDI Mapping Keys for hardware that I own or have access to. I know this device has been around for a while now and the silk screening does a pretty good job, but here’s my mapping key for the Default (built-in) djay mapping anyway.
Reloop Mixtour Pro — djay 5.6.7 MIDI mapping (built-in)
The Mixtour Pro is a 4-deck controller: the left side drives decks 1/3 and the right side decks 2/4, with MODE+LOAD (13) toggling which of the pair each side controls. Every deck control below is mirrored left/right.
KEY ACTION SHIFT or MODE (SECONDARY) ACTION
1 GAIN Deck channel gain
2 HIGH // VOCALS High EQ. Neural EQ mode: Vocals stem level.
3 MID // HARMONIC Mid EQ. Neural EQ mode: Harmonics stem level.
4 LOW // DRUMS Low EQ. Neural EQ mode: Drums stem level.
5 FILTER Bipolar filter (LPF left / HPF right)
6 NEURAL (N) Toggles the EQ knobs (2/3/4) between 3-band EQ and Neural Mix stem levels.
7 MAIN Master Volume - Not mapped
8 CUE VOL Headphone Volume - Not mapped
9 CUE MIX Cue/Main headphone blend
10 LINE FADER Deck channel volumes
11 CROSSFADER
12 BROWSE Browse library; turn to scroll (also seeks the track, or moves the loop-out point while looping). Push moves between sections. SHIFT: Library Back (push). MODE: Track Seek (turn)
13 LOAD Load track to this deck. MODE: Deck 3/4 Select
14 DECK MODE+LOAD=Switches the side between decks 1/3 and 2/4.
15 MODE Selects the pad mode: Hot Cue - Auto Loop - Bounce Loop - Sampler - Pitch Cue - Saved Loops - Instant FX - Neural Mix. Also enables other Secondary Actions.
16 SPLIT Single/Split pads: all 8 pads to one deck, or 4 per deck. MODE+SPLIT=Single, all 8 Pads for one deck
17 IN-OUT-EX Loop In / Out / Exit. Auto Loop on/off
18 SYNC Sync Key Match
19 CUE Sets a temporary cue point when paused, or returns to it when playing. SHIFT: Tempo Nudge (—). MODE: Key Shift (—)
20 PLAY Play/Pause SHIFT: Tempo Nudge (+). MODE: Key Shift (+)
21 PITCH BEND ◄► SHIFT: Nudges tempo down/up. MODE:
Key shift down/up
22 FX PADDLE Deck FX on/off. Push up (ON) latches; pull down (HOLD) is momentary. SHIFT: Backspin
23 PARAM ◄► Adjust the FX parameter. MODE: FX Select prev/next
24 DRY/WET FX depth (dry/wet)
25 DECK1 PRE-CUEING Deck 1 Headphone Pre-Cueing SHIFT: Crossfader FX Toggle
26 DECK2 PRE-CUEING Deck 2 Headphone Pre-Cueing SHIFT: Crossfader FX with tempo blend
27 PADS HOT CUE: Set/Trigger Hot Cue 1 - 8. BOUNCE LOOP: 1/32 - 1/16 - 1/8 - 1/4 - 1/2 - 1 - 2 - 4 beats. PITCH CUE: Pitch Play from the cue point, 8 steps. INSTANT FX: Instant FX 1 - 8. AUTO LOOP: 1/4 - 1/2 - 1 - 2 - 4 - 8 - 16 - 32 beats. SAMPLER: Trigger slots 1 - 8. SAVED LOOPS: Save/recall loops 1 - 8. NEURAL MIX: pads 1-4 toggle Drums - Bass - Harmonics - Vocals; pads 5-8 solo them. SHIFT: HOT CUE: Clear Hot Cue 1 - 8. PITCH CUE: Set the pitch-play cue points. SAMPLER: Pause slots 1 - 8. SAVED LOOPS: Reloop 1 - 8. Other modes repeat the primary layer.
28 MONO/STEREO Switch between Mono and Stereo Audio Output. Not mapped
S SHIFT Hold for secondary actions in the SHIFT column.
H HEADPHONES Headphone output (3.5 mm)
Pad modes in full (8 modes × 8 pads, base / SHIFT)
Pad mode is chosen with MODE (15); SPLIT (16) decides whether all 8 pads drive one deck or split 4-per-deck.
  • HOT CUE — Pads: Set/Trigger Hot Cue 1 - 2 - 3 - 4 - 5 - 6 - 7 - 8. SHIFT: Clear Hot Cue 1 - 8.
  • AUTO LOOP — Pads: 1/4 - 1/2 - 1 - 2 - 4 - 8 - 16 - 32 beat loops. SHIFT: same intervals.
  • BOUNCE LOOP — Pads: 1/32 - 1/16 - 1/8 - 1/4 - 1/2 - 1 - 2 - 4 beat momentary (bounce) loops. SHIFT: same intervals.
  • SAMPLER — Pads: Trigger sampler slots 1 - 8. SHIFT: Pause slots 1 - 8.
  • PITCH CUE — djay Pitch Play. Pads: play the track from the cue point at 8 pitch steps. SHIFT: set the cue points.
  • SAVED LOOPS — Pads: save / activate stored loops 1 - 8. SHIFT: reloop 1 - 8.
  • INSTANT FX — Pads: Instant FX 1 - 8. SHIFT: same (Instant FX 1 - 8).
  • NEURAL MIX — Pads 1-4: Mute Drums - Bass - Harmonics - Vocals. Pads 5-8: Solo the same stems. SHIFT: same layout.
Hidden modifier combos
Beyond SHIFT, the MODE button doubles as a modifier. These per-deck functions have no dedicated button:
  • Tempo − — SHIFT + MODE + CUE
  • Tempo + — SHIFT + MODE + PLAY
  • Loop Halve — MODE + IN-OUT-EX
  • Loop Double — MODE + SYNC
  • Loop In (move point) — SHIFT + MODE + IN-OUT-EX
  • Loop Out (move point) — SHIFT + MODE + SYNC
Global library / view combos:
  • Section back / forward — BROWSE push, Back=SHIFT+BROWSE push
  • Toggle waveform view — SHIFT + Deck 1 Neural Mix pad
  • Cycle view mode — SHIFT + Deck 2 Neural Mix pad
Definitely link to your post! Reloop Mixtour Pro - Custom MIDI Mapping
Thanks for sharing the link to my custom mapping @skymakai
