Pioneer DDJ-SX2 MIDI Mapping
Im using small jack…make sure your output options as master on 1/2 and monitor on 3/4 internal mode and you should be ok
Im cool with that. I havent had time to work on midi outs yet bc I was in a rush to get ready for gig…I plan on working on that this week. At least for channels 1/2
Fyi…I used on Fri/sat for a residency I had and had no issues at all.
Ill try later if I can find my 1/4 adapter. That was prob the easiest part of the mapping process
Im assuming so if its natively supported
Glad this update came out so I dont have to through the trouble of doing the rest myself.
I used at my residency this Fri/sat and it did well for the most part. Make sure you uncheck auto gain and limiter and your leds should work just fine.
Crossfader crapped out on me once… I may try in external mode
Channel Leds go in and out… auto headphone que is a little annoying.
When you open djp it will prompt you to setup your audio settings. Is should default to main out 1/2 and precue 3/4
Yup… have to have full program for it to mapp audio controls right
Idk, I open my program and the first thing it ask me is if I want to use sx2 for audio… main out, pre out, and mic… there’s a drop down menu to choose sx2
yes please share. i tried to switch between hotcue, roll, slice and sample but not sure how to.and how to get the one button in hot cue mode to be the set and the play cue button. please help.
Yea exactly how I did it. Thanks man, completely understand. I’m going to still try to find a way.
Did you guys manage to get the cue to work properly? I could only get the headphones to cue a channel if it was playing through the master… Also for some reason my gain level never goes silent, even when I turn the knob right now on the SX2, there is always a bit of volume. I’ve played with the advanced settings and got nowhere. Anyway, it’s the cue issue that is making my attempt unworkable at the moment
Hi mate, I had a look and for some reason there’s no option to PM you. I have a secondary email address for spammy stuff anyway, so if you could send it to that at noodall@yahoo.co.uk?
Thanks in advance, looking forward to testing it out
Well I downloaded the mapping and for some weird reason I still can’t get pre-cueing to work. I can’t seem to get the deck that’s not playing through the master to pre-cue in the headphones. So weird, since you guys seem to not be having this issue.
Weird, it’s lighting up the headphones, but there’s nothing coming out of them, the only sound I get is when you hit master cue, but I can’t isolate a channel in the headphones… Can you try the small jack (it’s all I have at the moment) and see if you get the same issue? Maybe just the large jack socket works…
Hmmm. Maybe I have a dodgy unit or something then. I’ve tried allsorts of combos to get the individual decks isolated in the phones, but to no avail. It’s clear your midi mapping is working as it is selecting the decks individually, but they’re not playing in the phones. So near yet so far! :slight_smile:
The channel LEDs did not work for me
