Please add a MIDI Action that quickly opens the Effects View on iOS on iPad.
Just simply in the same way as the “Browse” button opens the Track Browser, it should be possible to quickly open the effects view.
Use Case: Let’s assume a track is playing. You have your iPad in horizontal mode, 2 deck view. And you currently have the Hot Cue view open. Then you quickly want to enable an effect and change its parameters. Most smaller controllers do not have extra rotaries for controlling the effect parameters. So the effect parameters need to be adjusted via UI. But most of the time you can spare one button and it would help to assign it to quickly opening the FX view.
