iOS 18.0 on M1 iPad Pro; Djay Pro v5.2.3; Mixon 8 firmware 5339
Newbie to DJ Controllers. Went for Mixon 8 pro. Loving Djay Pro and 4 decks on iOS.
However, I am having some issues with the left-hand-side pads. The bottom left green only seems to occasionally work. And then seems to randomly trigger without being touched. Also hot cue behaviour of the other left-hand side pads is different to the right-hand-side. With the deck not playing, randomly they will autoplay when hotcued. Then behave normally: moving to cue point but and holding. The right-hand-side behaves normally consistently.
Also I am finding that sometimes the left-hand-side play button requires two taps to play which surely can’t be right?! (right-hand-side behaves normally: single tap to play / pause).
I am on the latest firmware, 5339, and am using the latest Djay Pro v5.2.3. I have reached out to both Reloop and my vendor but have yet to get responses. I was wondering if the issues I am experiencing align with those I understand some others have experienced with this controller.
