Return to previous library/playlist position after clearing search?
  • Device model: MacBook Pro 14”, 2021
  • Version of operating system: Ventura 13.6.3
  • Version of djay: 5.1.2
  • Hardware/controllers used: Pioneer DJM-S11 & 2 x Pioneer CRSS12
Hello!
When searching a playlist for a song and then clearing the search text box, djay jumps back to the top of the playlist. It would be nice if, after clearing a search, djay returned to the position it was at in the playlist before I initiated the search. With the current behavior I have to scroll all of the way back to where I was in the playlist, which can be annoying if I was pretty far down in a large playlist before starting the search.
If it’s not possible to automatically return to the pre-search position, a keyboard shortcut to jump to the location in the playlist for a song loaded on one of the decks would be helpful.
Does this functionality exist and I’m just missing it?
Hi @djcoldswitch, this is not currently possible. It’s pretty similar to 2 recent suggestions, so perhaps you can comment and add your votes there as well. Thanks!
  1. Changing Playlists
  2. Return to Previous Playlist when closing and reopening djay Pro
Thank you @Slak_Jaw !
You’re welcome @djcoldswitch
