Slow Import of large library and headphone issues
  • Device model M1 apple
  • Version of operating system 14.5
  • Version of djay 5.2
  • Hardware/controllers used pioneer xdjrx3
Have issue
+lag on import song more than 80k song
+when enable crossfader fx neural mix i cant listen que song on headphone
+when on wifi djay apps became lag
Hi @Ser, thanks for the details about your setup and the issues.
  1. Can you please elaborate on the lag issue with importing your large library?
  2. No pre-cueing with Neural Mix based CFX is a known limitation of the Neural Mix engine. The devs are aware of this and investigating options, but unfortunately this is not a simple fix (Headphone Cue Not Working with Crossfader FX).
  3. The WiFi lag has also been reported in another topic and the engineering team is already investigating this (Urgent Help needed! Major lag in djay).
