Songs momentarily freeze
We do not have a fix for this issue, yet. I am sorry for this.
Sorry, but still no luck! I’ve had a lot of input (thanks to all those who emailed support btw) but am still unable to reproduce this bug.
Do you have any other apps running in the background when this happens? Or better yet, does this also happen even if djay is the only app running on your device?
At this time, please simply provide as much information about your device/system as possible, even it seems irrelevant.
  • e.g. available disk space, amount of time until this happens, apps running in the background, features used in djay, etc…
I know it seems like we’ve forgotten this problem but we haven’t. It is just almost impossible to fix a bug that cannot be reproduced.
Hi Uwe,
Which device do you have?
This issue seems to occur more likely on external hard drives. Please try copying some of your songs to your Mac’s internal HD and see if the problem still persists.
Sorry to hear that. Have you tried analyzing your library (Library > Analyze Library)?
Hi Dan,
Are you using any external audio interfaces with djay? Your description sounds like a different problem.
Does this also happen with songs on your Mac’s internal HD?
Jo and Jan:
  1. Are you using songs on an external hard drive?
  2. Are you using any external audio devices?
I have the same thing happening on a Mac Mini (2Ghz Intel Core Duo 8Gb 1067 MHz)
No, it does it randomly in any playlist I have set up, whether Automix is set or not. The problem is how random and irreproducible it is.
The audio freezes at the same time as the animation. Frankly, I’m used to the animation freezing when I , for example, switch from the iTunes playlist I’ve got set up and the main library, but the music doesn’t stop when that happens. This is a full freeze on the music as well as the animation.
Hi Warren
I ain’t 100% sure but I have the feeling it’s only doing it in Automix playlist, not in Automix in the music library.
Not sure if this is of any help?
regards
Patrick
Hi Warren,
Both cut out just for a split second. Franl ́kly the animatin does not bother me. The audio cut out is disaterous during live performances. I recently started playing and love the programme. I am however now experimenting with other programmes as the cut-out is to serious during the dancing.
Thanks for looking at it. I love your programme and love to continue using it
regards
Patrick
Hi Warren
the issue is even worse with a mixer connected. yesterday I played live with a Numark Mixtrackpro connected. auch. in two hours I had about eight freezes :-(. it seems worse if I don’t listen to the pre cue first. As when I say eight times the pre cue freeze I don’t include. Is my computer to slow? I will try this week with the programme delivered with the mixer to see if there is issues then. Please, please solve this. You application is the one I want to use…
If you have a test / Beta version. I am willing to try it on Saturday /Sunday during a live performance (I know I am taking risks here for myself ;-). I could record the session
Hi Warren,
Small update, it’s also occasionally doing it when throwing a sample in
Just installed 4.06. Problem remains :-(. Please solve this problem, playing music without interruption should be the core strength of the programme.
Any news on the issue Warren???
Hi Warren
No other programs running, Wifi of, Bluetooth of. Problem is always present, gets worse when I connect my Mixtrack.
Bummer that you can’t reproduce it, considering that I am not the only one with the issue.
All i could say is, is there something that you could pinpoint if you look at the issues described in this threat. Change that parameter and let a few of us that have the issue test it.
