btw, I reduce the issue by listening to the pre-cue (so the problem then occurs in pre-cue), that seems to buffer better, this I do with the samples as well. I press all the samples before I go live
nope
I am off guys, 5 times issues during a live playback. I have offered to test possible beta versions. No reply. This is simply not good enough. Will need to swap over to another programme with maybe less user friendly look, but without cut outs. Drop us a line if you have new working versions or beta’s need t be tested.
Goodluck
I think they understand the priority now of getting this fixed. Perhaps they can give an update to the effects of “we have identified the problem and are working on a solution”.
That would go a long way, at this point.
I will try his fix but not before the weekend full of weddings. It won’t be until Sunday when I can rebuild my iTunes database.
Let’s hope this works!
Mine freezes ONLY on search and ONLY when it is connected to the Denon MC6000 MKII.
You want us to comment on our experience using Traktor on this forum?
They will fix the problem… they take their times and make sure things are fixed properly.
Hang in there.
Slow wi-fi…? I don’t even have wi-fi turned on. All my tracks are on my hard drive and I have slow search… Not sure what you even mean?
You dj a wedding with an iPad?
ABSOLUTELY, you should be concerned. I have dj’d 6 weddings in the past theree weeks and Djay Pro has CRASHED on my THREE times, in front of HUNDREDS of people. It just died!
Developers have personally told me that they will “let me know IF they find anything”.
That does not sound very confident at all.
In my opinion, DON’T USE IT until it works.
Updates happen VERY VERY slowly around here. Even with a show-stopping crash, it could be months for an update.
I am committed to this software. I just have my backup ready to go at all times.
Sad when you have crashes in a pro grade software.
Djay 2 is for iPad, which I would never dj a wedding with. DJay Pro is for Mac.
I use one for cocktails and dinner music. Other than that, I am only using an iMac and a Macbook Air.
Lenon, you posted the SAME THING like 5 times… we get it.
Stayed tuned for an update… The app has made AMAZING progress in the beta testing.
I have used this at 15 weddings with 100% success rate… absolutely no more issues for me.
Hang in there!
Huh?
You have to be on the beta test team to get betas.
Hello… You people DO realize that this issue has been going on for FOUR years and is it fixed yet? NO!
I have sent pictures, videos, everything they have asked for and not one fix has been done. They will blame it on “many different configurations” or something like that but the fact is, they just can’t fix it.
They have now resorted to erasing most of my posts that speak the truth. They don’t like when I say that they simply don’t know how to fix it. It makes NO sense when other software, that has MANY more features, is updated weekly but we wait for 8 months for updates and the the problems still exist.
Read this quick because the WILL erase it. Keep the pressure on them or demand a refund. It’s that simple!
I gave up and moved on but I still have an investment in the software, so I check back occasionally to see if anything changes. Nope, still the same.
When your music stops in front of hundreds or thousands of people, you will be as mad as I am. Or, when it stops in front of a bride dancing with her father… They tell me that their priorities are in order. Four years later, no fix… What do you think?
(Here comes the “delete button” from Lukas)
Hello,
I too have an issue using it on my iPhone…
Every song whether mixing manually or using automix, the sound cuts out, kinda like a scratching or skipping sound for 1-2 seconds. The animation also looks like it hesitates when this happens.
It does it 3-5 times per song, depending on the length of the song.
Otherwise, it’s a great app!
Regards,
Dean
whenever I close the next song I want to play the music pauses for about a second. I only have this problem with songs I have downloaded from iTunes. How can I fix this?
Song pause when choosing song downloaded from iTunes.
So obviously a lot of people have this problem and are not very happy about it. what is being done to solve thive problem, I check for the update to fix this bug everyday.
