Songs momentarily freeze
Just uploaded the new update. Songs are still skipping, pausing. Pretty frustrating
How do you switch to the older versions?
The only way I could suggest to reproduce this problem is to buy a song from iTunes and then try loading it onto a table while the other one is already playing a song. Mine only skips with songs I’ve purchased on iTunes from my iPad 2
Latest update still does not fix the problem
Yo Warren,
I’m also having the same problem. The recording will stop when it freezes. Apple has told me its a software problem. Please fix & due your updates.
Simon
I want my money back!!! It’s been at least 6 months and the problem is still not solved. How do I get my money back? What should I tell my friends at apple?
No, it happens to me too and I never use Automix. I have an online radio maixshow, and with DJay 3, it would always happen around or shortly after the 50 minutes mark. However, since the upgrade to Djay 4, its very random. On my show yesterday, the temporary freeze happened about 6 times within an hour. The freezes never last longer than 3 or 4 seconds, but thats critical when you are live and beat matching
I just emailed support three examples of the freezes from my radio mixshows. Also, for the first time yesterday, I was unable to manipulate the wheels on the ns6. I would turn the wheel and the music kept playing. After a reboot (after the show) it seems to be fine now
Well, I’m afraid that the time has come for me to move on to another app. Tonight I had 9 freezes in a two hour mix show. When you are mixin live and you are beatmatching and 1 of the tables freezes is critical. Guys you really have a good product overall. I really love djay…But, when program directors start to complain its time to do something.
Hi, I also have this problem wether I use a playlist or manually select the songs. It stops for a second when it changes from one song to the next. Please help.
I use the app on a iPad 2. it also happens when the screen goes to sleep. One thing I have noticed is that if i leave the screen in sleep mode then it does not happen when the song changes to the next.
Warren, can you give us a update please?
same issue on iPad 3, it freezes for a sec every time when loading a new song (doesn’t matter if automix or selecting manually) and the new song, or song on the other deck includes a cover. It runs flawless for me only if both loaded songs and new song haven’t any artwork. It runs better on iPad 1 than on iPad 3.
Warren, this affects also iPad 3. (see my post below)
It should be the same issue, read the whole thread - a similar bug while loading tracks affects apparently both iOS and Mac version.
To all: is your device jailbreaked?
Warren, this topic should be split to iOS related and OS X related.
tested djay 1.5 on iPad 1 – the playback freezes occanionaly like opening the library for the first time, or now and then while opening a library after a sleep.
tested djay 1.5 on iPad 3 – songs with artwork caused freezing
updated to djay 1.5.1 on iPad 3 – no freezes at all, it seems everything is fixed, running fine!
In recent versions it works fine:
djay 1.5.1 on the original iPad, iOS 5.0 = ok
djay 1.6.3 on iPad 3, iOS 6.1 = ok
I noticed it only cuts out when I load up a track with album art. Deleting the album art in iTunes and resyncing the song fixes it every time for me. Unfortunately then I don’t have album art in iTunes but at least it’s a fix for me.
They are looking into it and seem very interested in fixing this bug. I have been in correspondence back and forth with the devs in the last few days and upon their request, I have sent them a couple of songs with and without album artwork for them to test.
