I’ve just learnt that the Griffin DJ Connect works… Funny that. However I don’t understand why then the Audio 2 shouldn’t?
That makes total sense! Thanks so much for your input. this news is gonna make a lot of us happy!
Do you think there might be a chance that the Fiio e6 might work? That has its own battery supply
It’s a battery issue isn’t it. It’s because its a higher priority to Apple to show that “we’ve improved battery life” and sacrifice something than only a handful of us use.
Yes I would love to have to cart around a plastic cooker hob midi controller which I’ll have to pay £300. Algoriddim don’t care because they get a cut through licensing. However why should I do this only to find just when I’ve got a gig… That’ll be the day it won’t work because we’ve gone over to iOS9 and all third party app developers won’t of caught up.
I hate to say it but Djay and the controllers are just toys and we’ve exspected to much out of them.
OMG!!! My Line6 soundcard has started working again!!! I think the last ios8 update has fixed it!!! Everyone try your devices!!!’
No sorry false alarm… I’m sure it worked
I caved in and bought the DJ Connect but it’s rubbish… Sometimes it works straight off, other times it come out of 1 output. Then it works but with a static noise so you have to minimise the app the once it’s switched of bring it back up. It’s just s**t in comparison to my sonicport which used to do the same thing.
Me too.
Behringer uca202
does anyone know if this has been fix now since the IOS 8.1 came out, i can’t check because i don’t have my ipad at the moment. and won’t have it back for another week.
thank
my friend bought this cable and it works. I’ve just order one. Griffin dj cable:http://www.amazon.co.uk/gp/aw/d/B00AE…
I’m not sure, but my mixer has mono and stereo on it, i wonder if this will change it back to stereo. Any ideas?
Any news about this anyone?
Awesome, thanks
I’m gonna cry.
I’m gonna cry
USB 3d Sound Model HY554
Djay/Pioneer Wego has the same problems as above stated, this was noticed after upgrading from iOS 7 to iOS 8. No matter process either reboot or starting the devices in any order it will crash or audio will behave erratically. Also it will not work with traktor controller S4
This reply was created from a merged topic originally titled My imic does not work on my iPad, I bileve there is an issue with the latest os..
Sound comes out of the imic , but as soon as I plug into the headphone socket the imic no longer works!
