Please consider sharing a short video or screenshots to help clarify your issue
Hello, I would like to report a reproducible MIDI issue in djay Pro on Windows 11 25H2.
System:
Windows 11 25H2 (clean install)
Latest version of djay Pro 5.6.2
Numark Scratch (native support, official driver)
Issue:
After a system reboot, MIDI works correctly on the first launch of djay Pro.
However, once djay Pro is closed and then opened again:
The MIDI device is still detected and visible in djay
But it does not respond at all (no MIDI input/output)
ASIO audio continues to work normally
MIDI remains non-functional until the computer is rebooted
Additional note: Even other MIDI applications cannot use the device after djay has been closed. Only system restart helps.
Important:
The exact same hardware, drivers and djay version work perfectly on Windows 11 24H2 and previously on 23H2.
This issue only appears on Windows 11 25H2.
I’m not sure if the problem is only with the Numark Scratch mixer, but the DDJ-SP1 also stopped working (partially… the input was working but the leds on SP1 didn’t react). Nothing helps. Disconnecting devices, reinstalling Djay Pro. When I try to disable the device in Device Manager, the system freezes.
The same thing can happen simply by mapping new buttons. When you create a new MIDI map and click “Save,” the program stops responding to the device’s MIDI. Closing Djay Pro and reopening it doesn’t help, nor can any other program open the MIDI port to the Numark Scratch.
It looks like Djay pro doesn’t release the MIDI port for the device after closing the application.
After reinstalling the system on Windows 11 version 24H2, everything works without the slightest problem.
Okay, but please note that the sound works. The ASIO driver from Numark Scratch loads every time and the music plays. MIDI simply stops working when I close the program and doesn’t allow MIDI to be used with this device until I restart the computer.
I realize they are not the same and understand that yours is a MIDI issue not an Audio issue. I mainly meant the 2 issues are directly linked to Windows 11 25H2. Either way, I have shared everything above with our engineering team for further review. Thanks!
I think the problem is that in Windows 11 25H2, when you close Djay PRO, the application doesn’t close completely, because when you go into Task Manager, the application still appears open. What I do is force Djay PRO to close from Task Manager. Damián_Zbroinski, I think if you do that, you don’t need to restart the PC
I’ve noticed this. The application sometimes stays open in the task manager, and sometimes it doesn’t. However, even killing the process doesn’t change anything, and the problem persists. The MIDI port remains blocked every time I close Djay Pro. I spent the entire evening trying various solutions, but nothing worked. Switching back to 24H2 resolved the issue.
Microsoft has released a targeted fix specifically for issues with Jogwheel Seek and Fine Tempo Adjustments. They are planning to roll out this fix to all users in April/May, but have made it available for download/installation as a short-term fix as well (see link below).
Omg all was working fine on my Windows 11 24H2 with Djay pro 5.6.2. With the update 5.6.3 I have exact same problem that I had on 25H2.
For example, I edit the midi mapping in the program for my Numark Scratch mixer and it stops working (actually, every MIDI device stops working).
Update:
I checked Windows updates and found that the KB5079473 update had been installed on March 11th. After uninstalling it, everything went back to normal. I also had to reinstall the Numark Scratch driver. It can give you a headache.
I tried this patch “WinRT MIDI 1.0 Timestamp Fix microsoft/MIDI” but it doesn’t help. So far I see no solution other than NOT updating the system. I’m afraid of what will happen in the future.
This is all you need to do to fix it until Microsoft rolls out another update soon:
Press Win + R, type services.msc, and press Enter. Find Windows MIDI Service. R/H click it and select Properties. Change “Startup type” to Automatic. Click Apply and Start. Then everytime you start your computer it’ll make sure MIDI starts as normal. No need to uninstall any of the updates.
But sometimes the problem is this: the “djay” process can remain in Windows processes even though we’ve closed the program, and it prevents the MIDI port from being released. I’ve tried restarting the MIDI service in Windows in this situation, but it often fails because of this frozen process.
Hello everyone, we released a supplemental update to Windows djay 5.6.4 on April 10 which should fix the issue where MIDI controllers are not detected. We added a small workaround which should ensure that the Windows MIDI Service is started on app launch. I hope that helps!
