Updated macOS support info:
I have tried on my 2019 5K iMac, Sonoma 14.1.2, 3,6GHz 8core (i9), 64GB, Radeon Pro Vega 8GB, so far works fine on this, but on
2014 5K iMac, Catalina 10.15.7, 4GHz quad core (i7), 32GB Radeon R9 2GB has crashed every time if I have try to make right click on any track, but only in List View, not Album Cover view, immediately DJay Pro 5 go crash. Not just on my library, even Djay Music library too.
here is the latest report
Thanks for sharing @DJ-Z, this is very helpful and has already been forwarded to engineering.
I have reinstalled, but I have facing the same thing…
Yes, what is taking so long for Canada roll out? Fingers crossed it will be today.
Unfortunately it crashes for me too. MacBook Pro 13 year 2012. macOS Catalina version 10.15.7
How can I solve it?
I don’t know mate…they coming up with an update
@Sergio1 please submit an official support ticket through the app so we can capture more information about your specific hardware and the crash report. In the meantime can you please tell me what other DJ hardware you are using?
Any heat issues and/or throttling so far on the iPad M1? I ran mine for a couple hours and everything was normal. Gonna do a 4-5 hour gig this weekend and push it.
@DJ_A_Diffrance I’ve been testing for weeks on a 2020 iPad Air 4th gen with zero performance issues at Maximum (100%) Neural Mix Quality.
Cool!!! Thanks @Slak_Jaw.
I havent downloaded the update yet for Mac but am curious have the transition arrows on the left and right side of the crossfader been removed and replaced by the “mix now” from the crossfader fx drop down menu? I dont see the arrows anymore on the iOS app but what about on MacOs?
@DJ_A_Diffrance you’re welcome. Please report back on how your 4-5 hour gig this weekend goes!
@MrG yes, that is correct.
I will definitely do that.
I must say this a mighty fine release. Will fully test with my Mixon 8 this weekend.
Oh btw that annoying bug where edited maps wouldn’t show when restart controller and iPad is now gone. Good work.
Nice. Thanks @Slak_Jaw ! Once last thing, is that “mix now” midi mappable?
@MrG you’re welcome. In my personal testing the existing Transition to Left, Transition to Right and Transition to Inactive Deck MIDI commands worked with the new Mix Now on screen button.
Sweet!
So does the controller need to be plugged in to see and use the neural fx in the drop down menu? Cause all i see are the main fx transition fx.
Just updated on mac os.
