Djay 6.0 dream features?
As I’ve shared above several times now, I highly recommend that you make a new suggestion topic for each idea then I can share it with our devs for consideration and comment.
Cool, that means we dont have to dream anymore. We got direct access unlocked :wink:
It means if you make a suggestion topic, I will share it with the development team for consideration. It does not guarantee that it will be implemented. That decision involves multiple factors:
You can see exactly when vocals start/stop in the mix now in Djay Pro.
When you split the waveform it will breakout each element.
Exactly @gizmo
Yes but it’s nice also to have one waveform and still be able to see where vocal is.
I did not know this was a thing!
Hmmm this would be a cool feature on iOS/ipados. I didn’t realize it’s available
I’ll try this - great observation, see if it does what i’m aiming for. Thanks.
@eyeseeyou01 this is already available on iOS
Ah I see. By default the option for instrumental or vocal is there but you have to additionally and manually choose 2 neural mix tracks to display 2 waveforms.
is it possible to have it display that way by default?
No, this resets every time you launch djay. There is an existing suggestion topic for this if you’d like to upvote it though:
Cross device / platform compatability for the music.
1 its great that DJPro on mac can see my rekordbox collection and work seamlessly with that.
2 its great that my rekordbox on iphone can sync with rekordbox on mac
3 its great that my Rane system one with Engine OS can read my rekordbox usbs
so all of that frictionless from my one music collection (managed and prepared in RKB)
but
4 i cant easily use djproai on my iphone/ipad using the same one single music collection on my laptop - this may be an iOS sandboxing file management thing so apologies if it is - but the fact that rekordbox can do it makes me woner and hope
Lighting integration similar to engine DJ….
Thanks for the feedback @DjKozWare
@BillPayer ^^THIS^^ 100%
A simple date added would make me happy to find my latest tracks added. The Libary could be better. RB Libary is great at this. Just add it into the headings List ie BPM - Key - Artist - Date added.
I dont want to faff about making playlists in order to search my hole libary or find recent tracks.
Hi @RAWKEY, welcome to the Community! Thanks for the input.
Im sure you’ve already thought an out this but I always set a cue point where the vocal starts. Especially since now there are 16.
I do the same and rename it “Vocal Start”.
