I’ve recently purchased a Reloop Mixtour that I intend to use with my phone, a Samsung Galaxy S10. The Mixtour works fine with Djay Pro on Windows, but that’s not how I wish to use it. The problem is that even though the Mixtour controls Djay perfectly, there is no working sound.
Steps:
- Reboot phone
- Connect Mixtour via USB
At this point I have a notification about a connected USB device - Power on Mixtour
At this point, SmarThings has replaced the USB notification, and I can choose if I want audio to play through the phone or through the Mixtour. The Mixtour is chosen by default and I don’t change it. - Open Djay app
At this point, I can control Djay entirely with the Mixtour, and the Mixtour LEDs all make sense with the state of Djay. As soon as Djay opens, a buzz becomes audio on my speakers connected to the RCA output of the Mixtour. At no point do headphones work. When I turn the Mixtour’s master volume up all the way, I can faintly hear the music that Djay is playing, but it sounds absolutely awful, like it was compressed to a comically small bitrate or something. I can only tell it is actually the music from Djay because stopping in Djay makes it obvious.
This is very frustrating, and I am likely to try and return the Mixtour if I can’t get it solved.
