Oh this is a great breakdown. If it’s not available in the 5.1 I can recreate it.
on that note the midi mapping tool could use a search function. It’s crazy having to scroll through the ever increasing long list of midi functions.
Yeah something similar has been suggested in the topics below if you want to upvote them:
This is probably too much of a change, but maybe there’s ways around it.
I would prefer to have a master MIDI mapping option.
I have a computer with an iconnectivity interface, some RTP busses, and hardware controllers. I know the average user doesn’t mess with changing the channels and notes of hardware controllers, but for those that do - having a list of 15 devices is hard. I know that i wan…
Hi all,
First of all, it’s great to work with the flexible and non-technical MIDI mapping functionality in djay. I think it’s incredibly helpful that by pressing, turning, or moving a control on the MIDI device, the corresponding function is automatically highlighted in the configuration screen.
However, since there are hundreds of MIDI functions and many controls on modern controllers serve multiple purposes (such as pad banks or jog wheels with shift layers), the current layout of the MIDI m…
Problem
When assigning a function to a control in the MIDI editor, the user must scroll through a very long, single list of all possible actions (especially for deck fuctions). This is inefficient and time-consuming.
Solution
Restructure the function selection menu into a hierarchical or cascading system. Since the functions are already grouped (e.g., Beat Jump, Auto Loop), the user could first select a category, which would then reveal a shorter, more manageable list of specific functions with…
Ok great. Confirmed the stem split and stems pad mode works but for sure there has been some updates to djay pro that broke some of the mappings. The loop roll and auto loop pad modes may have been unintentionally completely remapped for different functions. I’ll go in and tweak it and update it.
Thank you for this. Very creative and useful.
Cool! You’re welcome @eyeseeyou01 . Glad you found it helpful.
