Hello djay community, I need the opinion of all Mixon 8 users, it’s to report problems to Reloop!
Can you please comment on this article confirming that you are experiencing the following problems like me:
→ Impossible to switch from “Neural Mix” mode to “FX” mode on all decks (SHIFT[48] + TAP[34]).
→ When you want to (SHIFT[48] + FX 2 Arm[30]) This command assigns an FX to Harmonic for decks 1 and 3, but we only want to assign it to deck 1 not 3.
Thanks in advance!
I can confirm that I have these same issues with the default mapping for my Mixon 8 on djay iOS.
ed-dj
July 6, 2023, 8:33pm
3
Hi @Clem_Coss I can also confirm I experience the same with default mapping.
I just got the Mixon 8 today iPad is crushing and I try it on my I phone 13 plus works for a little and then is crushing!!! I own Mixon 4 had some small issues nothing like this!!! I also saw some massage s they are experiencing same problems please help!!!
@Leo_Gertsios I recommend reading through this existing thread related to “Mixon 8 issues”.
Hi djay community, i use the Mixon 8 with latest firmware and update of djay, but i met a lot of problems with commands:
Numbers between […] are numbers controls buttons of the instructions manual.
On Deck 1 : SHIFT[48] + FX 2 Arm[30] → This command assign FX on Harmonic for Deck 1 and 3, but we want it just for the Deck 1 not for the Deck 3.
For all Deck : SHIFT[48] + TAP[34] → Doesn’t toggle between “Neural Mix mode” and “FX mode”.
Deck 2 and 4 : Button “vinyl mode” isn’t light when we do …
There are some tips here that could be helpful as well:
Continuing on from my recent Hardware (General Hardware Advice / Tips ) and Software Tips (General Software Advice / Tips ), I thought it would be helpful to provide some iOS specific tips to maximize Performance and Stability. I’ve been using djay on iPad and iPhone exclusively for my gigs for over 5 years now. Using the tips in the links above with the ones below, I rarely experience djay or iPad crashes.
Delete Unnecessary Apps. I treat my iPad as a professional piece of hardware dedicated t…
I recently posted some general hardware advice and tips (General Hardware Advice / Tips ) and thought it could be helpful to provide some software tips based on my last 5 years of DJing with djay Pro. Please note I’ve mainly used djay with Apple Operating Systems and only briefly on Windows. I have read most of the posts in this forum so I think I have a decent understanding of the main issues with Windows and Android though.
Turn Off Automatic updates for your Apps and OS.
a. Especially impo…
system
Closed
July 26, 2024, 11:55am
6
