STEMs Split & Dual Deck Modes
Please add Dual Deck Modes and the ability to Split STEMs across 2 Decks.
  1. Basic Mode: simply lock 2 Decks together so they can both be controlled by the Jog Wheel and Tempo Fader without switching between decks.
    a. Typically this will be Deck 1 & 3 or Deck 2 & 4.
  2. STEMs Split Mode: basically create an Instant Double of the currently playing track on Deck 1 over to Deck 2, but at the same time switch Deck 1 to Instrumental and Deck 2 to Acappella.
    a. By default, the tracks would be BPM and Beat locked together, but this could be disabled as well for additional flexibility.
    b. Obviously, we’d want the ability to do this in reverse as well (ex. Acappella on Deck 1 and Instrumental on Deck 2).
    c. This will enable independent EQing, FX, Cutting, Scratching, etc., of each STEM across the 2 channels.
Would be cool if algorithm takes what really works well from all the other platforms and incorporated into Djay pro AI plus adding their own sauce.
Several of the recent features coming to other softwares were done by Algoriddim first (streaming service integration, real-time STEMs separation, STEMs FX, STEMs EQ, even the new “Auto BPM Transition” on the Pioneer Rev 5 is basically djay’s Automix).
Good point. I remember rocking a party with a beatpad and Spotify. :sunglasses:
I was actually able to get pretty close to the STEMs Split functionality with a custom MIDI Mapping on my Reloop Mixon 8 Pro.
  1. I used the Duplicate function to map 3 MIDI commands to a single button.
  2. First I mapped Instant Double to SHIFT + Load Channel 2.
  3. Next I mapped Deck 2: Neural Mix Solo (2ch: Acappella) to the same button.
  4. Finally I mapped Deck 1: Neural Mix Solo (2ch: Instrumental) to the same button again.
  5. So, if I’m playing a track on Deck 1 and I press SHIFT + Load Channel 2 it will essentially put the Acappella onto Deck 2 and switch Deck 1 into an Instrumental.
  6. With Slip and Sync engaged, you can pretty much keep the Instrument and Acappella locked together even when scratching.
  7. Here’s the mapping if anyone with a Mixon 8 wants to try it out:
    Reloop Mixon 8 Pro SJ4(Split).djayMidiMapping (320.2 KB)
I like the way you think its awesome! Now for your next mission ahould you chose to accept it. Try mapping the bpm transition. :notes:
This is very cool. Great mapping skills.
Here’s the mapping key to go with the Reloop Mixon 8 Pro MIDI Mapping above. White Text represents regular button functions and Orange Text represents SHIFT + functions.
“Now for your next mission ahould you chose to accept it. Try mapping the bpm transition. :notes:” @SamJam that was super easy actually:
Would love to see this feature implement. Whether it’s a controller or dj mixer
Adding to this, I’d actually love the option to split all four stems across four decks, and have the decks locked together, ostensibly in slip mode, with the cues in gate mode. This would add quite powerful mixing/remixing functionality.
Is there a way to do dual deck control on the reloop MIXON 8?
Specifically let’s say mixing vocal stem in channel 1 and instrumental stem in channel 2…is there way to combine them into one deck and use deck 3 or 4 to mix in a third song?
I know the FLX 6 and FLX 10 have this feature.
If not natively available is there a way to MIDI map it?
Hi @avi530, please use the search function before creating new topics. I’ve merged your new topic with this existing one. Please see above and use the blue Vote button at the top left to show your interest in adding this functionality. Thanks!
Stem split is pretty nice. Pioneer did a good job implementing this in Rekordbox and DDJ-FLX10. Press a button and vocal and instruments get split onto two decks either same side or opposite sides of the crossfader, based on a setting. Decks can stay locked together or separate. Amazing for scratching a vocal from the same track that is playing underneath. Unfortunately, no one does stems as good as Djay so doing this in Serato or RB sounds like garbage!
  • Device model Macbook Pro M1 Max:
  • Version of operating system MACOS 15.6:
  • Version of djay Latest:
  • Hardware/controllers used (Pioneer DJ XDJ-XZ:
Hi guys
As simple as it sound: where is that function? i cant find any info about it or the related MIDI action (or just a simple FULL list of actions DJAY can MIDI map).
Technically speaking, its possible. it exists on the FLX10 and Rane’s 4 channel controllers so DJAY knows how to do that.
Please help me make it happen somehow. creative ideas are welcome.
Hi @Shay_Manshary, welcome to the Community! There currently is no single MIDI command for STEMs Split. However, see my workaround above. It’s a bit more MIDI mapping effort, but it’s been working well for me. I hope that helps!
+1 on the Dual Deck Mode feature request. Now that Deck Move has been implemented it would be awesome to have Dual Deck Mode.
Example usage would be:
  • Have tracks playing on decks 1 and 2
  • Deck Move the track on deck 1 to deck 4 (now I have a mashup going on decks 2 and 4)
  • Turn on Dual Deck Mode for tracks 2 and 4
Then I could:
  • Scratch turntable/jogwheel assigned to deck 2, but since Dual Deck Mode is on, I’m scratching decks 2 and 4 simultaneously
  • Trigger hardware or software fx on deck 2, but since Dual Deck Mode is turned on; the fx are applied to decks 2 and 4 simultaneously
  • Fader changes for deck 2 also affect deck 4 in Dual Deck Mode
I hope that makes sense.
Thanks for the additional input @djcoldswitch
