Hi! I‘m using djay Pro AI 4.0.3 in my iOS devices with iCloud Sync activated.
Is it possible to sync (create and maintain) a playlist on both devices?
Hey EISERMANN, this is not possible currently but is the most wanted feature in this forum. Please see here: Syncing My Library Playlists between Devices
To keep things organized, I’ve moved your post over to this already existing thread about the same topic. Thanks for sharing your request!
Continuing the discussion from Syncing My Library Playlists between Devices:
I have same issue. I usually prepare everything on my desktop just for the large screen and the fast speed. Everything for a while was syncing via the cloud to my MacBook Pro but after one of the updates it would completely wipe out my playlist on both devices. This is ver annoying. It appears that I now have two music folders with the djay folder in both. One is in my iCloud Drive and the other is on the actual hard drive on my desktop (a Mac mini running Monterrey) my MacBook Pro is on Big Sur but I am going to upgrade to Monterrey if it will work with my ten year old MacBook Pro to see if that resolves the issue. The music is all from various sources but consolidated into one folder on my iCloud Drive. I also have an iPad Pro and would also like all three to sync via iCloud.
Hi @gdbrickey,
Thanks for posting to the community again!
Your additional feedback regarding this topic is greatly appreciated.
To keep things organized, I’ve moved your post over to the already existing thread you mentioned above. Thanks for sharing your request!
+1 on this. Need to be able to sync playlists between iPad, iPhone, and Macbook Pro please
Hello Team,
So getting a new iOS device means physically checking every song to correct beatgrids previously corrected on old device.
Getting a new Mac is a whole different animal.
What a nightmare!
I simply cannot figure out how the years pass without this feature existing.
Sorry gang, no satisfaction on this issue.
I would admit part of my frustration is with migration for new iTunes which I always push on this forum.
A simple let down
This needs to be a priority. It is absurd such a basic function is not implemented.
Yes please make this a priority!! I’ve built extensive playlists on my macbook and it has been my preferred way of building and curating my music collection. However, I want to start performing with the iPad and the fact that I can’t sync all my work from the macbook into the app is absurd!! Please make this a reality soon <3
Incredible that its now going to be the year 2023, where syncing things across multiple devices is a no brainer, and Algoriddim is still a sleep at the wheel.
I would say that this is the most essential need on this app!
DJ Ai Pro?? It’s not so pro!! ![]()
Please prioritise this feature. Hardware failures aren’t uncommon. The ability to simply and preferably automatically sync/backup playlists etc and therefore be able to switch between devices should be baked in to the software. What’s the hold up on this guys?? Do you have a new feature roadmap? Thanks.
Merry Christmas to all — hoping that 2023 will be the year where you can easily manage your DJ collection across devices. ![]()
Please vote here: Public Roadmap request
This seriously needs to be implemented. I love DJay Pro AI across my devices but increasingly now I have the need for playlist syncing across devices. Like DJ Engine or Rekordbox it can be done and a mobile device can be used for curation. So I’d love to be able to use my iPad sometimes instead of my Mac for gigs but would prefer to make the playlists on my iPhone and access on my iPad or Mac. So for now I’m just using my Mac as I’m confined to one device so I picked one. It has to change soon tho. It may seem like a small thing but it’s actually a huge feature that is going to make or break DJay soon if they do or don’t implement it.
As a new user checking out djay for the first time this was a key priority. Surprised to see it’s not a thing already.
Any other DJ apps around that have both the AI ‘stems’ feature and syncing between devices?
this has been open for two years, so there is clearly not much urgency.
Is there no way of doing this simply with Dropbox just as Rekordbox has then importing the playlist file from Dropbox rather than the one inside your DJay folder? I don’t see an extra option being difficult to implement when you have Dropbox connected.
I would pay extra for this as that means I can setup cue points and saved loops on my phone or other iPads.
Thanks,
Rob
+1
Allow storage of audio files and library database in cloud sync services such as Dropbox and iCloud Drive.
I would like that as well. Right now i’m still using the standard music app to sync files from mac to iPad. But if we could use a cloud folder that all devices can read to keep files in sync that would be great.
Main point for me is syncing the library database though.
My wild guess : the database/medialibrary format is totally different on each platform.
So it’s not just copy paste operation from device to device like from macOS to iOS.
At least on windows and macOS the media library db totally different.
