I believe that VDJ is waiting for some firmware fixes/support from Pioneer. So, presumably the same goes for Algoriddim.
Hereās my unofficial DDJ-FLX4 MIDI Mapping. Itās about 95% complete.
Trying it out rn brotha! Thank you for mappin this for us!![]()
Thanks for this bud, really appreciated. Iām using your mapping but the jog wheels arenāt working apart from stopping the tracks dead. Is this what youāre experiencing? Didnāt know if it was me getting a setting wrong.
Thanks for that. I took a look and updated the MIDI mapping to version 2.2. Check the notes for the changes to the Jog Wheels. Not sure if will solve your problem, but you should be able to scratch with the top and pitch blend with the sides (while track is playing).
Notes: Thereās a sensitivity issue with the jog wheels that I donāt understand yet. Playing around with it to find the optimal settings. Sometimes if you touch the sides first, it will scratch until you then touch the top, then the sides starts to pitch blend. On the plus side, the side/pitch blend seem to work correctly when the track is playing.
Thanks for the reply. Iāve downloaded your new mapping but unfortunately itās still the same. Perhaps itās worth mentioning that Iām using Djay on iPad. Has anyone else tried this mapping using an iPad? If so it it working for people.
This could also be related to the firmware issue referenced earlier.
I confirmed that the āofficialā Algoriddim Jog Wheel mappings on several other controllers are setup exactly the same as the FLX4 jog wheel mapping.
But there are differences in the sensitivity settings for different controllers. The two sensitivity settings for the jog wheels are:
- Speed (Slow to Fast)
- Reaction (Smooth to Responsive)
- The sensitivity settings on the DDJ-FLX4 mapping are defaults from DDJ-400 mapping, but the FLX4 jog wheels appear to have a different design - so perhaps the FLX4 mapping needs different values. Just for a reality check, the current settings work fine (for me) on my controller - both in macOS and iOS.
Notes:
- I donāt know if this solves your issue but thought it would be worth exploring.
For Reference, here are screen shot comparisons between the DDJ-FLX4 and Hercules Starlight jog wheel mappings.
SCRATCH Mapping (top of jog wheel) DDJ-FLX4
SCRATCH Mapping (top of jog wheel) STARLIGHT
PITCH BLEND Mapping (side of jog wheel) - FLX4
PITCH BLEND Mapping (side of jog wheel) - STARLIGHT
Hi, I know we have an unofficial mapping which I have been using and itās great. But when can we expect the official one? any timeline? Canāt wait to try those effects in sets.
Djay support, Any updates on supporting flx4?
@Maston82 - check the newest update to the FLX4 MIDI MAP. I made some changes to the Jog Wheel mapping. Hopefully it works better. Might even solve some of the issues on the FLX6.
The problem is that itās not plug and play right now. DJay recognizes the controller but you should set manually all the buttons and functions. And as you understand this is a titanic task.
hello, when you say MIDI maps, do you mean setting manually every button? Or is there a shorter way to do it?
@Amin_Azali if you read through this discussion, you will find that @Michael_Wisniewski has already completed a non-official manual MIDI mapping for this controller and has shared his mapping here. Simply download it and select it in the djay MIDI mapping section.
Hi Iām looking to buy a flx4 was just wondering can you map the controller from a iPad or download the map on a iPad and apply it
@Liam_Ridler yes, you can create a custom MIDI map on djay for iPad and download MIDI Mapping files to an iPad.
Cheers mate could you explain how I would be able to use the download In the app
- Use the Files app on your iPad and move the downloaded MIDI mapping file into the folder labeled ādjayā within the āOn My iPadā Location.
- Then open the djay app with your controller connected.
- Open the djay Settings and scroll down to MIDI devices
- In the next screen select your controller under MIDI DEVICES
- In the next screen, near to top left under MIDI CONFIGURATION, select your controller again
- Finally, in the next screen you can select the name of the MIDI mapping file you downloaded.
That should do the trick.
There is a new update, but unfortunately still no support of the FLX4. But well, we continue to wait⦠Pioneer itself unfortunately with the announced update of Rekordbox for mobile devices also apparently not progressed, so that the controller is now several months standing around unused and slowly but surely dust.
